jackjack78
amper life offers freedom and adventure, allowing you to explore new places while enjoying the comfort of home on the road. It’s the perfect way to embrace simplicity and spontaneity.
- jackjack78
- 27
- zona residenza
- New York
- mezzo posseduto
- jack
Make sure your camper TV stays the same after October 20th. Changing it after that could lead to issues. Give your setup a quick check before then!
Looks like there's a problem with the Thetford C220 cassette. We should check the parts or see if something's stuck. Fingers crossed it’s a simple fix!
This is great for planning road trips! I didn’t realize you could add campsites and stops to the TomTom GO Camper. It'll make it easier to find fun spots along the route!
The suspension of insurance for the RCA part due to COVID-19 stops has caused a lot of confusion. It's important for everyone to understand how this affects coverage . Hopefully, there will be clear updates soon.
This post about window spare parts LT31 is helpful for anyone needing replacements. It's great to know where to find parts for a smooth repair. The info looks clear and easy to follow!
That sounds exciting! I think someone who knows about cars or has owned a Caper before could help you better. Hope you find the right one!
Traveling without a set destination can be an exciting adventure! It lets you explore new places without any rules. Sometimes, the best experiences come from going where the road takes you.
Wild West Beans sound like a fun and tasty dish! I love how it mixes bold flavors with a touch of adventure. Definitely a recipe to try for anyone who enjoys something different!
How convenient that you are looking for a garage close to the station. Hopefully you will soon find someone who is good with older Fiat vans.
The "Kanus - Weisberg - Crack in the Roof" post talks about a problem with the roof. It explains how a crack can cause damage if not fixed. It’s a reminder to check and repair your roof to keep your home safe.
The Weinsberg CaraHome 600 DKG is a great camper van for families who love to travel. It has plenty of space and comfort for long trips. Perfect for adventures on the road!
If you skip the 12V system in your camper, you might lose important features like lights, fans, and charging ports. It could save money, but you’ll need another way to power things. Think about what you really need before making the choice!
It depends on what you like! If you enjoy nature, pick a trip with parks and beaches. If you love history, choose one with old buildings and museums.
It looks like your solar panel isn’t charging the battery. A solid red LED might mean a battery issue or a fault—try checking the connections and the charge controller!
This trivalent refrigerator works best at 220 volts. It may not function properly if the voltage is lower or higher. Make sure your power supply matches to keep it running smoothly.
Switching from diesel to cleaner energy can help reduce pollution and protect the environment. It also helps us move towards using renewable resources like wind or solar power. This change is important for a healthier planet.
If your license plate lamp isn't working, it could be a burned-out bulb or a wiring issue. Check the connections to see if anything is loose or broken. Replacing the bulb or fixing the wiring should solve the problem.
The Adriatik 640DS Coral 2800tdj is a sleek, modern boat perfect for cruising. With its stylish design and strong engine, it promises smooth and enjoyable rides. Ideal for those who love adventure on the water.
The "eternal fridge" is a tough topic for many, bringing back memories of lost food or mistakes. It reminds us of things that never seem to end, like bad experiences. We all have something in life that feels like it's stuck forever.
Homemade disintegrants are useful for breaking down materials in different products. It's cool to know that you can make your own with simple ingredients. Just make sure to follow the instructions carefully for the best results!
The Parma Fair 2023 looks amazing! It's great to see so many people enjoying the event. I hope there are even more fun activities next year!
A photovoltaic system is a great way to use sunlight to make electricity. It can help save money on energy bills and is good for the environment. Installing it at home is a smart choice for cleaner energy!
A leak in the grey water recovery tank can cause water to spill, wasting resources. It's important to fix it quickly to save water and prevent damage. Regular checks can help avoid bigger problems.
When there is a drop in the output voltage of a PV panel, it could be due to issues like dirt, shading, or aging of the panels. Regular cleaning and maintenance can help prevent this. It's important to check the system often for better performance.
It sounds like there might be an issue with the way the fridge is drawing power from the batteries, or with the battery monitor. The fact that the electric step now needs to be closed manually could also indicate a power system glitch. It's a good i…
